TwinTurbo.NET: Nissan 300ZX forum - Im starting to think it was a typo
Subject Im starting to think it was a typo
Posted by amp300zx on June 13, 2008 at 9:22 PM
  This message has been viewed 147 times.
In Reply To I never heard of someone putting a z over .o40 over (n/m) posted by RedTTZ91(OK) on June 13, 2008 at 08:56 PM
Message Only because I know you can customize your piston size. Ben said they are 87.5mm, but I dont think with that size of a piston you can go over .040 so I'm thinking that's what it is. You would need a larger piston, like a 90mm for that much of a bore. I have seen .075 bore though when I used the search feature. I know you can customize your compression (these are 8.5:1 ration), but I dont think .075 bore on a 87.5mm would even work. I will check again with the owner.
